ProjeQtOr free project management software - [SOLVED] Filter reset missing in "Planning" - ProjeQtOr
12 May 2021 10:13 #1 by Coasterman
The filter reset button in the gant views would be helpfull, because otherwise resetting the filter is complicate for some users.
Following situation:
I generated a filter which I use in the gant view in "Planning", searching for "responsible" --> set dynamic.
1) set the filter (choose a responsible)
2) all the projects are correctly filtered for the selected responsible
3) filter reset button is missing
4) switching between different view (e.g. "Planning" -> "Activities" -> "Planning"), doesn't help. The filter is still active in Planning
5) select the filter again, click on cancel (projects in "Planning" remained filtered)
6) switch between different view (e.g. "Planning" -> "Activities" -> "Planning") filter cleared.
I've simulated this also in the online demo, where I've logged in as "member"" (filter: responsible), where the outcome was the same.
12 May 2021 16:53 #2 by Damian.sd
You right, its an ergonomic feature we can add to Projeqtor.
We create ticket #5505 to follow this feature.
Regards.
14 May 2021 10:03 #3 by babynus
To disable an active filter, just select the fist filter choice "no filter clause"
