ProjeQtOr free project management software - [9.0.6] Spurious state and/or Responsible change for deliverables - ProjeQtOr
10 May 2021 09:50 #1 by fsouliers
we have many deliverables, among many projects.
the automatic planning calculation is on (running at 4AM and starting 10 days ago, I changed it Thursday or Friday, it previously was «from the beginnig of the week»).
This morning, almost all of our deliverables are in the same state (quality of the deliverable). In the history of each item, the change has been made by no user (as it is always displayed when the automatic planning calculation does something). It seems that all the deliverables that are linked to a milestone have been spuriously updated (deliverables not related to any milestone kept their «quality of the deliverable» unchanged).
With the same approach, I already had problems while updating the responsible of a deliverable : the value I selected was applied to all of the deliverables of the project. This problem disappeared in v9.0.6 but something seems quite unstable in this area.
Many thanks for your help,
10 May 2021 15:07 - 10 May 2021 15:11 #2 by Flou
Your ProjeQtOr version is still V9.0.6 ?
if so, try upgrading to V9.1.3, and tell us if that fixes the problem.
Last edit: 10 May 2021 15:11 by Flou.
17 May 2021 11:55 #3 by fsouliers
Hello, I upgraded to 9.1.3 this week-end.
I check this week if the problem still exists.
17 May 2021 18:03 #4 by fsouliers
Well, it is more than strange ...
If I calculate the planning for all the projects (even manually), the bug occurs.
I tried with a single given project ... and the behavior is correct.
I mean, in other words for this project :
- if I calculate it alone, the "quality" of its deliverables are not impacted
- if I calculate all the projects, the "quality" of its deliverables are impacted
I feel like if one of my projects were messing it all, but how ? Is the SQL request secured ?
19 May 2021 18:59 #5 by babynus
Recorded as Ticket #5511
We'll have a look
20 May 2021 14:30 #6 by fsouliers
I am investigating: it seems the problem started after we created a delivery object. Could it be related ?
The problem is currently quite easy to reproduce: where could I add some trace to understand what happens ? (and obviously send you the logs if it can help)
