ProjeQtOr free project management software - Real Work Imputation not working - Page 2 - ProjeQtOr
01 May 2021 13:01 #7 by mika095
Unfortunatly, nothing is locked. Some ressources can input their word some cannot.
Other suggestions ? Tks
03 May 2021 12:46 - 03 May 2021 12:48 #8 by babynus
Is the issue about inputing some work "for themselves" or "for another resource" ?
IT it's the second choice, then this user does not have rights to change timesheet for this resource.
See constraints in specific access rights.
Last edit: 03 May 2021 12:48 by babynus.
04 May 2021 04:28 #9 by mika095
Is s about their own imputation, "for themself". As I said, even if I gave them administration rights, their could not imput their own work.
Tks
05 May 2021 10:26 - 05 May 2021 10:27 #10 by babynus
Very weird.
We cannot reproduce this issue and cannot find possible source.
Can you please answer these questions step by step :
  1. Run consistency check and fix (in administration screen). Does is brings things better ?
  2. Assign the concerned resource A to another activity, already assigned to another resource B who can enter time on this activity. Does the resource A can input work on this activity.
  3. Assign another resource B who can enter time on another activity to the activity where the concerned resource A cannot enter work. Does the resource B can input work on this activity ?
  4. Did you use full standard code or did you change some code ?
Last edit: 05 May 2021 10:27 by babynus.
07 May 2021 03:11 #11 by mika095
Yeah, that's weird behavior.
Question 1
The audit identified errors, regarding the assignment of tickets to activities, which have been corrected. No evolution after that
Question 2:
We had already performed this scenario. The problem remains the same
Question 3: The same.
Regardless of the activities, I have one resource with normal behavior and two others that cannot charge their own work.
Question 4: No, we haven't changed the code. The only changes are the updates.
Is it possible to reinstall a new version with the current database?
09 May 2021 20:35 #12 by babynus
Question 2:
So issue is only linked to resource, not to the activities.
This won't change anything
