ProjeQtOr free project management software - difference between selected project and content of the project in multiple tab - ProjeQtOr
15 Apr 2021 14:52 #1 by frouze
I noticed the following small bug when you want to have 2 or more tabs in your web browser pointing on projeqtor with différent content.
Here is how i can play the bug :
  • Open Projeqtor in your browser
  • use the project selector for project "A"
  • select the button of meetting (or something else no amtter)
  • click on one of the proposed meeting in the list
  • open another tab whith projeqtor (using the appropriate button)
  • You open it on projet "A"
  • Select Project "B" and metting or something else.
  • edit ont of the meeting. Evreithing is ok
  • go back to tab 1
  • save the edited meeting in tab 1 et you'll see the meeting of project "B" in the liste while the seleceted project is still project A on top of page.
Have a good day
15 Apr 2021 18:27 #2 by babynus
You found one of the limitations on muti-tab use : selected value in the selector is applied to all tabs.
So if you change it on second tab, lists on first one are also changed.
