ProjeQtOr free project management software - Problem using screen 'absences' - ProjeQtOr
12 Apr 2021 08:56 #1 by magast
Hello and good morning,
after upgrade to Version 9.1.0 it is not pssoible to use the screen 'Absences' correctly.
For me its not possible to set the 'Daily duration of absence' or select any value to this field. The time of work in setting is comlete and correct.
Is there any problem in this module or wrong usage ?
Best regards.
Markus Gasteiger
12 Apr 2021 10:24 #2 by Arkhanje
we have no bugs or anomaly on the absences screen on our side. Do you have errors in your browser console? Are there any errors in your last log file?
If so, can you post them?
And just in case, I give a quick reminder to record your absences:
1 / Select the absences line that interests you. In your case, there is only one, therefore, line # 17 - Urlaub. It must be selected.
2 / Then fill in the field manually or by clicking on the duration shortcuts, which will retrieve the schedules according to what you have entered in your global parameters
3 / Finally click on the calendar days to enter your absences. The boxes will be colored with the color of your line.
Have a good day !
12 Apr 2021 14:58 #3 by magast
I think there is another problem:
As you can see in the screenshot there is not time in the field daily absence duration.
If i try to log in as 'admin' the time in this field is set.
I think this is a error in configuration ?
13 Apr 2021 07:34 #4 by magast
Please could you tell me if there is a differenc betwee user 'admin' and another user who is in group 'admins' ?
13 Apr 2021 14:32 #5 by babynus
Admin has nothing different from others.
It is just that this value is set, by default to the Capacvity of selected resource, and cannot exceed this value.
So I guess your resource has capacity equal to zero (so he cannot register unavailability)
14 Apr 2021 07:33 #6 by magast
Success !!
This does the trick.
Thank you ... also for the very good support.
Have a nice day
Markus
