ProjeQtOr free project management software - Organization do not show - ProjeQtOr
24 Mar 2021 17:47 #1 by Durou C
I can't display the Organization field on project screen !
find bellow the extract of log file:2021-03-24 17:36:26.920 ***** ERROR ***** [V9.1.1] EXCEPTION *****
2021-03-24 17:36:26.920 ***** ERROR ***** [V9.1.1] on file '/var/www/projeqtor/view/objectDetail.php' at line (547)
2021-03-24 17:36:26.920 ***** ERROR ***** [V9.1.1] cause = Class name must be a valid object or a string
2021-03-24 17:36:26.920 ***** ERROR ***** [V9.1.1] => #0 /var/www/projeqtor/view/objectDetail.php (278) -> drawTableFromObject()
24 Mar 2021 19:05 #2 by babynus
Replied by babynus on topic Organization do not show
Can you explain issue you get, clearely ?
NB : logged error has nothing to do with Organization
24 Mar 2021 20:58 #3 by Durou C
Replied by Durou C on topic Organization do not show
In fact,  on the project area, I do not have the Organization field. I thought that it was in customization menu, option do not display... But no! Everything in customization is OK...  wrote:
25 Mar 2021 09:23 #4 by babynus
If you have customized the screen "Project" have a look at customization.
Possibly Organization appears at an unexpected place.
Just move it back where you want it to appear.
25 Mar 2021 10:20 #5 by Durou C
I clear the customization, and also i do not have the organization field ????
25 Mar 2021 13:15 #6 by babynus
I guess you did not enable module "Organization".
