ProjeQtOr free project management software - 9.0.6: Direct Ticket Links (to Tickets) Still Don't Work (UI-independent) - ProjeQtOr
16 Mar 2021 20:34 - 16 Mar 2021 20:34 #1 by gohrner
The direct ticket links still don't work for me in ProjeQtOr 9.0.5, even tough Ticket #5277 is marked as "delivered" in the ProjeQtOr Roadmap.
The screen which opens whenever I use a direct link looks as follows:
There don't seem to be any errors in the logs any more, however it still only shows an empty page, neither in the server log nor in the Javascript console.
The Javascript console only issues some warnings:
dojo.js?version=V9.0.5.0280:2 [Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/. 5 [Violation] Added non-passive event listener to a scroll-blocking event. Consider marking event handler as 'passive' to make the page more responsive. See main.php?directAcces…t&objectId=116:1130 [Violation] Added non-passive event listener to a scroll-blocking 'wheel' event. Consider marking event handler as 'passive' to make the page more responsive. See https://www.chromestatus.com/feature/5745543795965952 main.php?directAcces…t&objectId=116:1195 [Violation] Added non-passive event listener to a scroll-blocking 'wheel' event. Consider marking event handler as 'passive' to make the page more responsive. See https://www.chromestatus.com/feature/5745543795965952 main.php?directAcces…t&objectId=116:1208 [Violation] Added non-passive event listener to a scroll-blocking 'wheel' event. Consider marking event handler as 'passive' to make the page more responsive. See https://www.chromestatus.com/feature/5745543795965952 main.php?directAcces…t&objectId=116:1221 [Violation] Added non-passive event listener to a scroll-blocking 'wheel' event. Consider marking event handler as 'passive' to make the page more responsive. See https://www.chromestatus.com/feature/5745543795965952 main.php?directAcces…t&objectId=116:1234 [Violation] Added non-passive event listener to a scroll-blocking 'wheel' event. Consider marking event handler as 'passive' to make the page more responsive. See https://www.chromestatus.com/feature/5745543795965952 dojo.js?version=V9.0.5.0280:2 [Violation] 'DOMContentLoaded' handler took 812ms [Violation] Forced reflow while executing JavaScript took 75ms projeqtor.js?version=V9.0.5.0280:180 => 65ms | page='../view/menuNotificationRead.php' | destination='drawNotificationUnread' (server:60ms, client:5ms)
Last edit: 16 Mar 2021 20:34 by gohrner.
17 Mar 2021 11:23 #2 by babynus
Which browser are you using ?
17 Mar 2021 16:17 #3 by gohrner
Chromium Version 87.0.4280.66 (Offizieller Build)
Built on Ubuntu , running on neon 20.04 (64-Bit)
18 Mar 2021 09:44 #4 by babynus
If you replace line 584 in file view/main.php
          echo 'var delay=(dojo.isFF)?1000:10;';
with
          echo 'var delay=1000;';
Does it fix the issue (after reconnextion) ?
The following user(s) said Thank You: gohrner
18 Mar 2021 11:08 #5 by gohrner
18 Mar 2021 11:15 #6 by babynus
OK, we'll generalize it.
