ProjeQtOr free project management software - Projeqtor compatibility with PHP installations for upgrades and rollback - ProjeQtOr
09 Mar 2021 02:12 #1 by Arthurk
Hi, first post here, so I may have missed some existing information but did the search for rollback and noting came back.
On the note of registration, the niggly bit - captcha does not work in firefox browser - no way of registering or communicating. This one is from Safari on Ipad so it worked.
Issue of installation: Projeqtor v8.3.6 stopped working after Hostgator upgraded to PHP 7.4 from 5.6 - I asked them to put php 5.6 back and PQ works for now.
I sent them in chat the list of pre-requisites from the installation instructions but no comment on that. Then I noticed that About PQ shows a number of external libraries and versions used for the PQ.
Not easy to work out a compete environment requied for a given release version.
My installation is a few releases behind and I am happy to upgrade to v9 but have no clear path to ensure that:
1. I have all components set up properly for php 7.4 - what is the correlation between php version and PQ versions?
2. Have no roll-back procedure in case I upgrade to a higher version of PQ and have lo go back to a lower version of PQ to continue.
3. Have concerns about the database structure upgrade with new PQ releases - best would be to state: no DB structure upgrade
The product is great and I would be happy to contribute more improvements for critical professional use at a better level than some expensive commercial platforms that are easily corruptable.
Best regards.
ArthurK
09 Mar 2021 09:03 #2 by babynus
The answer is on the website : www.projeqtor.org/en/product-en/technica...uct-prerequisites-en
Save DB before upgrade.
To rollback : Restore DB and overwrite new code with old one.
There is no other "rollbacks" procedure (not rollback scripts for DB)
There are always DB structure updates with new versions (Vx.y.0).
There are only fixes on patchs (Vx.y.z)
