ProjeQtOr free project management software - email problem for creating notes - ProjeQtOr
03 Feb 2021 23:21 #1 by nhedhili
hello
when we add a note we see that email is sent but wr do not receive ant thing.
email config is ok brcause we receive emails when we send directly emails from projeqtor ajso thee configuration for sending alrt when craete a note s ok
version çs9.03
error seen in yhe log is 2021-02-03 20:14:52.441 ***** ERROR ***** [V9.0.3] Error sending mail
2021-02-03 20:14:52.441 ***** ERROR ***** [V9.0.3] SMTP Server : smtp.topnet.tn
2021-02-03 20:14:52.442 ***** ERROR ***** [V9.0.3] SMTP Port : 25
2021-02-03 20:14:52.442 ***** ERROR ***** [V9.0.3] Sendmail path : /usr/sbin/sendmail -t -i
2021-02-03 20:14:52.442 ***** ERROR ***** [V9.0.3] Mail stored in Database : #5877
thanks for yout hrlp
05 Feb 2021 21:27 #2 by babynus
I think you use Global Parameter "Send emails as current user". to "Yes".
Set it to "No" : your email server doesn't accept mail with sender different from connected user (smtp account)
05 Feb 2021 22:52 #3 by nhedhili
Good afternoon
Thank you for your reply , yes it is the case I. Will set it to no and make the test than let you know
06 Feb 2021 12:43 #4 by nhedhili
hello
I chaged Global Parameter "Send emails as current user". to "No". and does not work , same situation test email works , direct email works , only emails when someone adds anote does not work : we that email is sent but we do not receive any thing.
thank you for your help and assistance
