ProjeQtOr free project management software - menuNewGuiLeft.php can't load if connection fails - ProjeQtOr
02 Feb 2021 15:49 #1 by Coasterman
In the new GUI the Left menu can't load "projeqtor.org/admin/getPlugins.php"2021-02-02 16:13:12.393 ***** ERROR ***** [V9.0.3] on file '/var/www/projeqtor/view/menuNewGuiLeft.php' at line (365)
If lucky it comes an error and it can be switched to old GUI else it hangs and wait until reload (depends a bit on the browser)
Old GUI works fine because no access to external sources needed.
02 Feb 2021 15:59 #2 by babynus
Your server cannot acces the internet.
Specify it on the php.ini file with
allow_url_fopen=off
You can also change global parameter "check version" to NO.
02 Feb 2021 18:01 #3 by Coasterman
Yes, this is true that the server couldn't access at that time. But the problem/question is, if it realy has to fail loading the complete menu just because it couldn't get the information about the plugin once? Because the information of new version available is a nice feature and saves daily manual check.
If it could be discovered and aborted already inbetween line 360 and 366
  if (ini_get('allow_url_fopen')) {
    enableCatchErrors();
    enableSilentErrors();
    $currentVersion=file_get_contents($urlPlugins);
    disableCatchErrors();
    disableSilentErrors();
or the lines 367 - 369 are skipped if no internet to let the list empty, the problem wouldn't apear...
