ProjeQtOr free project management software - impossible to configure automatic ticket from mails - Page 2 - ProjeQtOr
11 Feb 2021 10:04 - 11 Feb 2021 11:55 #7 by scud167
I did add lines in models and views (both parameters.php files)
However I still have this problem that arises.
I removed my rule of "mark as read" on my email address (microsoft messaging) and I see that the emails are indeed marked as read as soon as the corresponding ticket is created, but continue to create tickets in a loop.
I specify that my connection string is of the type:
{webmail.*********/pop/notls}INBOX
Last edit: 11 Feb 2021 11:55 by scud167.
11 Feb 2021 20:14 #8 by babynus
It's none of them that need to be changed, it is the one whose location is defined in file /tool/parametersLocation.php.
Default location is files/config, but this should be changed to securise the instance.
12 Feb 2021 10:49 - 12 Feb 2021 10:53 #9 by scud167
Ah yes, so I added this parameter to the file, but unfortunately it does not solve the problem of looping ticket creation. (I rebooted the server after modifying the file)
In the attached screen, there are only two mails in the box, and they are both already read.
Thank you very much for your help =)
Last edit: 12 Feb 2021 10:53 by scud167.
