ProjeQtOr free project management software - [SOLVED] Error on v9.0.1 on Project Expense - ProjeQtOr
14 Jan 2021 13:25 #1 by Yannobi
Hi
When i change the state of an expense, an error occurs.
Message on the log :2021-01-14 13:25:18.118 ***** ERROR ***** [V9.0.1] ERROR *****
2021-01-14 13:25:18.118 ***** ERROR ***** [V9.0.1] on file '/var/www/html/projeqtor/model/persistence/SqlElement.php' at line (6197)
2021-01-14 13:25:18.118 ***** ERROR ***** [V9.0.1] cause = Undefined variable: currencyPosition
15 Jan 2021 12:21 #2 by harvester
Hi
I confirm this when attempting to assign a risk to a project (assigned step)
15 Jan 2021 13:01 - 15 Jan 2021 15:19 #3 by karl.binet
V9.0.2
i'm having the same error when i'm trying so send by mail an order to provider.  when I select ok, i'm having the same error
I'm also having this error when I'm changing the Status of an Client quotations.
Last edit: 15 Jan 2021 15:19 by karl.binet.
15 Jan 2021 16:56 #4 by Flou
hello,
see the response of babynus of an other topic  :  error currencyPosition .
That should be help you .
The following user(s) said Thank You: Yannobi
21 Jan 2021 09:53 #5 by Yannobi
Fix is to add 2 lines in model/persistence/SqlElement.php after line 6029, like this :public function drawMailDetailCol($colArray, &$msg){
$currencyPosition = Parameter::getGlobalParameter ( 'currencyPosition' );
$currency = Parameter::getGlobalParameter ( 'currency' );
