ProjeQtOr free project management software - [SOLVED] KANBAN does not work anymore on v9.0.2 - ProjeQtOr
14 Jan 2021 11:09 #1 by bvd
Same behaviour, same problem, same version, but solution provided here (track.projeqtor.org/view/main.php?direct...Ticket&objectId=5178) did'nt work for me.
Here are the lines modified in /var/www/html/pilot/view/kanbanView.php :
$query="SELECT $tableName.id as id,
                $tableName.name as name,
                $tableName.id".$typeKanbanC."Type as idtickettype,
                $tableName.idStatus as idstatus,
                if(property_exists($typeKanbanC, "idUrgency"))$query.="$tableName.idUrgency as idurgency,";
                $tableName.idProject as idproject,";
Something wrong ?
14 Jan 2021 11:39 #2 by bvd
SOLVED : his is the right way to correct (I did a mistake) :
    if(property_exists($typeKanbanC, "idPriority")) {
