ProjeQtOr free project management software - [SOLVED] Kanban not working - ProjeQtOr
13 Jan 2021 16:03 #1 by TOST
Kanban not working was created by TOST
Good afternoon,
i have an issue with the brand new version 9.0.2 (thks a lot for the new interface), kanban actually don't work anymore
i found this message in the logException-[42S22] SQLSTATE[42S22]: Column not found: 1054 Unknown column 'activity.idUrgency' in 'field list'
I have from some other topic to unselect the column from the visualization, but i cannot find a way to to that in the Kanban view
Thks in advance,
Stefano
13 Jan 2021 17:38 #2 by SL
Replied by SL on topic Kanban not working
Good afternoon,
Same things for me since the update from 9.0.1 to 9.0.2.
The number of activities exists but columns remain empty
I've just went back to V9.0.1 and the kanban screen displays correct infoGood afternoon,
I've just went back to V9.0.1 and the kanban screen displays correct information.
Best regards
Stephane
File Attachment:
File Name: logerror.txt
File Size:6 KB
Best regards
Stephane
13 Jan 2021 17:48 - 13 Jan 2021 18:05 #3 by Flou
Replied by Flou on topic Kanban not working
indeed there is an issue, ticket  #5178  as recorded, the fix will be realeased for v9.0.3.
For fixed this:
- in kanbanConstructPrinc.php   (ligne 29)
replace "if($line )" to "if(isset($line )) "
- in KanBanview.php
delete  "$tableName.idUrgency as idurgency," (ligne 694)
and add " if(property_exists($typeKanbanC, "idUrgency"))$query.="$tableName.idUrgency as idurgency,"; " (ligne 695)
Last edit: 13 Jan 2021 18:05 by Flou.
The following user(s) said Thank You: SL
