ProjeQtOr free project management software - Follow-up->Absences ==> ERROR - ProjeQtOr
13 Jan 2021 13:02 #1 by alukats
after update to 9.0.2 we get red error on
ERROR : An error occurred on 2021-01-13 at 13:01:25
Absences, what could cause it? Everything else seems to work still ok
13 Jan 2021 17:20 #2 by Flou
Replied by Flou on topic Follow-up->Absences ==> ERROR
Your issue is on planning view or in absences view ?
can you join screenshot please.
14 Jan 2021 09:14 - 14 Jan 2021 10:02 #3 by alukats
Hi the error comes in 2 cases
pasteboard.co/JJztM92.png
this error happens for all users that have actual work assigned, if I set all work to 0 then the error for given user does not appear, the error comes on FIRST day with assigned work
and in absence view
pasteboard.co/JJzvxeS.png
Last edit: 14 Jan 2021 10:02 by alukats.
15 Jan 2021 16:09 - 15 Jan 2021 16:13 #4 by Flou
I can't reproduce this, can you show your log files to better define the source of the error.
Your datatbe is on  Postgres or mysql ?
What is your php version ?
Last edit: 15 Jan 2021 16:13 by Flou.
15 Jan 2021 18:23 #5 by babynus
Can you please post error that is logged in projeqto rlog file ?
21 Jan 2021 15:26 - 21 Jan 2021 15:47 #6 by alukats
Db: mariadb 10.3.17 (mysql)
PHP 7.4.8
BUG #1
Additional note this error only happens with old legacy GUI, with new interface it is not coming.
from log:
2021-01-21 15:31:45.106 ***** ERROR ***** [V9.0.2] on file '/var/www/html/pm/htdocs/model/Absence.php' at line (255)
2021-01-21 15:31:45.106 ***** ERROR ***** [V9.0.2] cause = Undefined variable: mediumTextButton
BUG #2
[root@shop logs]# tail projeqtor_20210121.log
2021-01-21 15:22:10.284 ===== TRACE ===== NEW CONNECTED USER 'antti.lukats' (using remember me feature)
2021-01-21 15:22:27.630 ***** ERROR ***** [V9.0.2] ERROR *****
2021-01-21 15:22:27.630 ***** ERROR ***** [V9.0.2] on file '/var/www/html/pm/htdocs/model/PlannedWorkManual.php' at line (346)
2021-01-21 15:22:27.630 ***** ERROR ***** [V9.0.2] cause = Division by zero
this is the line with error
$height=intval($size*($real-$realAdmin)/(($capacity)?$capacity:$resObj->capacity));
a DIRTY fix to:
$height=intval($size*($real-$realAdmin)/max((($capacity)?$capacity:$resObj->capacity),0.1));
fixes the red error ! sure this is not correct fix..
additional note: I have logged to projeqtor from different PC with different language settings, so sometimes comma is , and sometimes its . maybe related somehow?
Last edit: 21 Jan 2021 15:47 by alukats.
