ProjeQtOr free project management software - [SOLVED] Kanban with activity and Actions - ProjeQtOr
13 Jan 2021 12:02 #1 by 3m2t
Congratulations for your product.
I would create Kanban for activity and actions, but unfortunately, activities or actions do not show on the column. It works well on ticketing and requierements.
I read the the User guide and the forum but I didn't see the solution.
Thanks a lot for your answer.
13 Jan 2021 18:10 #2 by Flou
thank you for the return indeed there is an error, I have already replied on another post and giving the correction, I'll let you see that:  link to correction
14 Jan 2021 11:08 #3 by bvd
Same behaviour, same problem, same version, but solution provided did'nt work for me.
Here are the lines modified in /var/www/html/pilot/view/kanbanView.php :
$query="SELECT $tableName.id as id,
                $tableName.name as name,
                $tableName.id".$typeKanbanC."Type as idtickettype,
                $tableName.idStatus as idstatus,
                if(property_exists($typeKanbanC, "idUrgency"))$query.="$tableName.idUrgency as idurgency,";
                $tableName.idProject as idproject,";
Something wrong ?
14 Jan 2021 11:38 #4 by bvd
SOLVED : his is the right way to correct (I did a mistake) :
if(property_exists($typeKanbanC, "idPriority")) {
