ProjeQtOr free project management software - [SOLVED] index error when creating a since migration to V9.0.1 - ProjeQtOr
[SOLVED] index error when creating a <Question> since migration to V9.0.1
07 Jan 2021 17:17 #1 by nicolas@nasdron.be
Creation of a <Question> generate this error:
2021-01-07 16:55:12.680 ***** ERROR ***** [V9.0.1] ERROR *****
2021-01-07 16:55:12.680 ***** ERROR ***** [V9.0.1] on file '/home/www/projeqtor/model/persistence/SqlElement.php' at line (5983)
2021-01-07 16:55:12.680 ***** ERROR ***** [V9.0.1] cause = Undefined index: Treatment
Is there a workaround ?
Thanks!
Nicolas Nasdrovisky
07 Jan 2021 18:32 - 07 Jan 2021 18:36 #2 by Flou
indeed there is an issue, ticket #5164 is registred.
to fixed this add "if(isset($colArray))" one file '/home/www/projeqtor/model/persistence/SqlElement.php' at line (5983), before "self::drawMailDetailCol($colArray, $msg);".
Or waited for the release of 9.0.2 which will be done very soon.
Last edit: 07 Jan 2021 18:36 by Flou.
08 Jan 2021 13:06 #3 by nicolas@nasdron.be
Thanks for your help. It works after updating <SqlElement.php>.
Here is the new line 5983:
if(isset($colArray)) self::drawMailDetailCol($colArray, $msg);
Thanks for the great job!
The following user(s) said Thank You: Flou
