ProjeQtOr free project management software - V8.6.1 No display in Global Planning - Page 2 - ProjeQtOr
28 Dec 2020 16:51 - 28 Dec 2020 16:52 #7 by rainbow
I changed the add line to
$paramDbCollation='latin1';
yet still no item is displayed.
I also tried to add a new activity in the menu, yet the issue still persists.
It seems like the collation is not recognised. I extracted parts of the error codes below and attached full error log.
2020-12-28 23:24:58.053 ***** ERROR ***** [V8.6.1]    Strack trace :
2020-12-28 23:24:58.056 ***** ERROR ***** [V8.6.1]    #0 Sql->query called at [C:\Users\Rainbow\Downloads\Wnmp\html\projeqtor\tool\jsonPlanning.php:286]
2020-12-28 23:24:58.058 ***** ERROR ***** [V8.6.1]    #1 include called at [C:\Users\Rainbow\Downloads\Wnmp\html\projeqtor\view\globalPlanningList.php:534]
2020-12-28 23:24:58.061 ***** ERROR ***** [V8.6.1]    #2 include called at [C:\Users\Rainbow\Downloads\Wnmp\html\projeqtor\view\globalPlanningMain.php:79]
2020-12-28 23:25:02.369 ***** ERROR ***** [V8.6.1] Exception-[HY000] SQLSTATE[HY000]: General error: 1273 Unknown collation: 'latin1'
2020-12-28 23:25:02.372 ***** ERROR ***** [V8.6.1]    For query : SELECT planningelement.*
File Attachment:
File Name: projeqtor_...2-28.log
File Size:642 KB
Will the different version switching has any impact on the database such that changing to an older version will cause such impact?
Before such error, in V8.5.1 there is no such error. After I updated to V9.0.0, I encountered some issues, which I then tried to change to an older version V8.6.6, yet no display in global planning. I then tried to change to V8.6.1, yet the issue still persists.
Thanks!
Last edit: 28 Dec 2020 16:52 by rainbow.
28 Dec 2020 17:47 #8 by babynus
Possibly the source comes from your migration process.
You installed a new DB which does not use that same collation as the previous one.
Migrating from DB that has no issue will not introduce any issue.
08 Jan 2021 11:15 #9 by rainbow
Hi Babynus,
Thanks for your reply. I tried to use a new database that works at v8.5.5 and update to v8.6.6 but still didn't work.
I found out that the parameter script (as below) in V8.6.6 is missing after upgrade from v8.5.5 to v8.6.6. I suspect in the version update script, scripts on the parameter update are missing.
$enforceUTF8='1';
After adding the script above, the global planning display works. I suspect updating the version update script for UTF8 settings would prevent similar cases in the future version updates. Hope it helps others who face the same issue!
Thanks,
Rainbow
23 Sep 2021 13:40 #10 by K.KOUASSI
where i execute the command
$enforceUTF8='1';
23 Sep 2021 14:09 #11 by babynus
K.KOUASSI post=31254 wrote: where i execute the command
$enforceUTF8='1';
We won't reply to questions you add on an existing thread and that not relative to this tread. Please open new thread / subjet.
