ProjeQtOr free project management software - IMAP configuration for office365 - ProjeQtOr
18 Dec 2020 17:55 #1 by mcanuto
we just changed our email provider to the offer office 365. And we are have troubles to configure ProjeQtOr.
We keep receiving this errors (Under tls or ssl config):
2020-12-18 17:43:27.165 ***** ERROR ***** [V8.6.3] Error sending mail
2020-12-18 17:43:27.165 ***** ERROR ***** [V8.6.3] SMTP Server : tls://smtp.office365.com
2020-12-18 17:43:27.165 ***** ERROR ***** [V8.6.3] SMTP Port : 587
2020-12-18 17:43:27.165 ***** ERROR ***** [V8.6.3] Mail stored in Database : #25621
2020-12-18 17:43:27.165 ***** ERROR ***** [V8.6.3] PHPMail error : SMTP Error: data not accepted.SMTP server error: DATA END command failed Detail: STOREDRV.Submission.Exception:SendAsDeniedException.MapiExceptionSendAsDenied; Failed to process message due to a permanent exception with message Cannot submit message. 0.35250:881A0000, 1.36674:0A000000, 1.61250:00000000, 1.45378:02000000, 1.44866:A5240000, 1.36674:0E000000, 1.61250:00000000, 1.45378:AA240000, 1.44866:1C010000, 16.55847:A8120000, 17.43559:0000000024020000000000000000000000000000, 20.52176:140F468E1A00F01F00000000, 20.50032:140F468E8A17F01F00000000, 0.35180:140F468E, 255.23226:AE1B SMTP code: 554 Additional SMTP info: 5.2.0
2020-12-18 17:43:27.165 ***** ERROR ***** [V8.6.3] PHPMail debug :
2020-12-18 17:43:38.817 ***** ERROR ***** [V8.6.3] ERROR *****
2020-12-18 17:43:38.817 ***** ERROR ***** [V8.6.3] on file '/var/www/html/projeqtor/model/ImapMailbox.php' at line (86)
2020-12-18 17:43:38.818 ***** ERROR ***** [V8.6.3] cause = imap_open(): Couldn't open stream {outlook.office365.com:995/imap/ssl/novalidate-cert}INBOX
2020-12-18 17:43:38.827 ***** ERROR ***** [V8.6.3] [CLOSED] IMAP connection broken (server response)
2020-12-18 17:43:38.838 ***** ERROR ***** [V8.6.3] ERROR *****
2020-12-18 17:43:38.838 ***** ERROR ***** [V8.6.3] on file '/var/www/html/projeqtor/model/ImapMailbox.php' at line (86)
2020-12-18 17:43:38.838 ***** ERROR ***** [V8.6.3] cause = imap_open(): Couldn't open stream outlook.office365.com
2020-12-18 17:43:38.838 ***** ERROR ***** [V8.6.3] imap_open(): Couldn't open stream outlook.office365.com in ImapMailbox.php at line 86
2020-12-18 17:43:38.838 ***** ERROR ***** [V8.6.3] Error while executing CRON script : fix the source issue and manually restart the CRON Process
2020-12-18 17:43:38.838 ===== TRACE ===== Cron::run() - Error on checkEmails()
2020-12-18 17:44:33.883 ***** ERROR ***** [V8.6.3] Error sending mail
2020-12-18 17:44:33.884 ***** ERROR ***** [V8.6.3] SMTP Server : ssl://smtp.office365.com
2020-12-18 17:44:33.884 ***** ERROR ***** [V8.6.3] SMTP Port : 587
2020-12-18 17:44:33.884 ***** ERROR ***** [V8.6.3] Mail stored in Database : #25622
2020-12-18 17:44:33.884 ***** ERROR ***** [V8.6.3] PHPMail error : SMTP connect() failed. github.com/PHPMailer/PHPMailer/wiki/Troubleshooting
2020-12-18 17:44:33.884 ***** ERROR ***** [V8.6.3] PHPMail debug :
Can you help us doing a proper configuration, please?
And also for the inputmailbox…
Thanks a lot.
MCanuto
21 Dec 2020 09:09 #2 by babynus
For first error (SMTP), contact Office365 support for help.
For second error, as it is a Cron task, possibly you are still using old paramters.
Try and restart the Cron.
21 Dec 2020 10:19 #3 by mcanuto
babynus wrote: For first error (SMTP), contact Office365 support for help.
Is ProjeQtOr compatible with the MAPI4 protocol?
24 Dec 2020 12:14 #4 by babynus
We are using PHP IMAP feature.
So compatibility with IMAP 4 may depend on your PHP version
29 Dec 2020 10:47 - 29 Dec 2020 10:49 #5 by mcanuto
if this can help someone else, I share with you what we found and it's working for us, for the inputmailbox :
serveur IMAP :
{outlook.office365.com:993/imap/ssl/novalidate-cert}
For now, we didn't find yet the good configuration for the Emails sending under the Global parameters.
Best regards,
MCanuto
Last edit: 29 Dec 2020 10:49 by mcanuto.
29 Dec 2020 11:00 #6 by babynus
Thanks for sharing.
I'll post this on Hint section
