ProjeQtOr free project management software - [SOLVED] Mac Installation Issue - ProjeQtOr
13 Dec 2020 19:59 #1 by Blaise Jadoul
Hi there !
I just installed a brand new MAMP on my MacBook Pro in order to be fine with the PHP and mysql configuration.
After that I installed (or at least tried to install) the last version of Projeqtor.
After having clicked on the OK button at the bottom of the "http://localhost/projeqtor/view/main.php" page, I got this red message :
SQLSTATE[HY000] [2054] The server requested authentication method unknown to the client
dsn = mysql:host=127.0.0.1;port=3306
I'm a bit upset because I really would like to use your great tool ;-)
Can you help ?
15 Dec 2020 17:04 #2 by babynus
Replied by babynus on topic Mac Installation Issue
Possibly your installation do not use port 3306.
Sometimes port 3308 is used (often when xAMP install both MariaDB and MySql)
15 Dec 2020 17:09 #3 by Blaise Jadoul
Can you explain how I can check this?
I don't know much about PHP and mysql...
15 Dec 2020 17:22 #4 by babynus
Open your MAMP interface.
Or my.ini
15 Dec 2020 18:07 #5 by Blaise Jadoul
Well, it seems to be 8889
