ProjeQtOr free project management software - [SOLVED] Connection lost after synthesys is selected in ticked dashboard - ProjeQtOr
02 Dec 2020 18:58 #1 by Coasterman
I've logged in the the Track database (roadmap) as guest.
As soon as i do following actions it will go back to login page and say that the connection was lost:
1) select "Tickets dashboard"
2) select any of the "Synthesis ..." (e.g."ProjeQtOr V8.6.1 [25.09.2020]")
3) it will show the "Tickets" screen but no Tickets in the list and show "Connection Lost. Please reconnect" at the top
4) any click on the left menu (e.g. "Kanban") will lead back to the login screen (which also says "Connection Lost. Please reconnect."
If after point 3) the search is accessed, circles will appear and if then 4) is performed (click on other topic) the "Information" popup appears with "Query is ongoing. Please wait.", which can be clicked away by "x" but not "OK" --> only page refresh helps in this case.
03 Dec 2020 11:03 - 03 Dec 2020 11:28 #2 by Flou
disconnection after clicking on Synthesis on ticket dashboard is a problem, thank you for reporting the information to us.
I do not reproduce the other errors.
Last edit: 03 Dec 2020 11:28 by Flou.
