ProjeQtOr free project management software - Force https connection / Forcer la connexion https - ProjeQtOr
22 Nov 2020 16:17 #1 by Kbp
English version :
Hello, I cannot force the connection to my platform in https.
However, I modified the .htaccess file
Can you help me?
cordially
Current version: V8.6.6
Browser: Google Chrome
Version originale :
Bonjour, je n'arrive pas à faire forcer la connexion à ma plateforme en https.
Pourtant j'ai modifié le ficher .htaccess
Pouvez-vous m'aider?
Cordialement
Version actuelle: V8.6.6
Navigateur: Google Chrome
22 Nov 2020 19:58 #2 by babynus
Possibly your apache does not allow to take .htAccess in account
Best is to set a virtualhost.
Here is an exemple
<VirtualHost *:80>
    ServerName projeqtor.yourserver.com
    DocumentRoot /var/www/projeqtor
	RewriteEngine on
    RewriteCond %{HTTPS} !^on
    RewriteRule ^(.*) https:/projeqtor.yourserver.com$1 [QSA,L,R=301]
</VirtualHost>
<VirtualHost *:443>
   SSLEngine on
   SSLCertificateFile /etc/ssl/projeqtor.cer
   SSLCertificateKeyFile /etc/ssl/projeqtor.key
   SSLCertificateChainFile /etc/ssl/AlphaSSLCA-SHA256-G2.cer
</VirtualHost>
<Directory /var/www/projeqtor>
        AllowOverride all
</Directory>
yourserver.com and SSL files must be adapted to your config.
23 Nov 2020 19:15 #3 by Kbp
English version :
Thank you for your reply.
But unfortunately, I still cannot schedule the redirect.
The default content of the .htaccess file is:
<IfModule mod_rewrite.c>
  RewriteEngine On
  RewriteCond %{REQUEST_FILENAME} !-f
  RewriteCond %{REQUEST_FILENAME} !-d
  RewriteRule ^(.*)$ index.php?uri=$1
</IfModule>
AuthUserFile "./.htpasswd"
AuthName "ProjeQtOr"
AuthType Basic
require valid-user
I host the platform at OVH, he tells me to do it like this:
RewriteEngine On
RewriteCond %{SERVER_PORT} 80
RewriteRule ^(.*)$ https://www.mypersonaldomain.ovh/$1 [R,L]
Can you tell me how I should interpret their instructions in relation to your answer?
Version originale :
Merci pour votre réponse.
Mais malheureusement, je n'arrive toujours pas à programmer la redirection.
Le contenu par défaut du fichier .htaccess est:
  RewriteEngine On
</IfModule>
AuthType Basic
require valid-user
J'héberge la plateforme chez OVH, il me dit de faire comme ça:
RewriteEngine On
Pouvez-vous me dire comment je devrais interpréter leurs instructions par rapport à votre réponse ?
Cordialement,
23 Nov 2020 19:56 #4 by babynus
Just replace your config (into IfModule) with what they propose.
The following user(s) said Thank You: Kbp
