ProjeQtOr free project management software - [SOLVED] Cannot set working imap string for Exchange IMAP connection - ProjeQtOr
05 Nov 2020 11:41 #1 by bvd
HI,
is there a way to get imap connection working with an exchange imap server ?
F1 documentation lookup didn't helped me.
The string used is : {mail.domain.com:143/imap/notls}INBOX
The logs in degub mode give us :
2020-11-05 11:21:50.644 ===== TRACE ===== Cron::run() - Error on checkEmails()
2020-11-05 11:21:50.645 ***** ERROR ***** [V8.6.3] ERROR *****
2020-11-05 11:21:50.645 ***** ERROR ***** [V8.6.3] on file '/var/www/html/pilot/model/ImapMailbox.php' at line (86)
2020-11-05 11:21:50.645 ***** ERROR ***** [V8.6.3] cause = imap_open(): Couldn't open stream {mail.domain.com:143/imap/notls}Inbox
2020-11-05 11:21:50.645 ***** ERROR ***** [V8.6.3] imap_open(): Couldn't open stream {mail.domain.com:143/imap/notls}Inbox in ImapMailbox.php at line 86
2020-11-05 11:21:50.645 ***** ERROR ***** [V8.6.3] Error while executing CRON script : fix the source issue and manually restart the CRON Process
What kind of username formatting do we need ?
NB : mail.domain.com is not the hostname of our mail server, just an example replacement there
05 Nov 2020 19:26 #2 by babynus
Check configuration of server.
Does it allow remote connections on port 143.?
Is the IMAP server configured on port 143 ?
Are you sure about the /notls option ? I saw /ssl /nossl /tls but never /notls. Possibly you could try with other option or without an option.
Also try INBOX in upper case.
06 Nov 2020 11:15 #3 by bvd
We finally got it working.
It was an Exchange 2019 issue based on connectors definition.
I close this thread.
