ProjeQtOr free project management software - Planification problem - Predecessor End to Start not respected - ProjeQtOr
17 Sep 2020 09:36 #1 by QUANTAMEDICAL
Hi team projeqtor;
We need your help because we encountered a problem with planification.
On a project that use predecessor chaining rule, we have many task that are planified to start before predecessor ending.
All task concerned are test session plannified on planningMode : as Soon as possible (9)
there is only one predecessor by task (testsession)
Planning of both task
Detail of predecessor test session (with end date on red)
Detail on successor test session with contraint date
Database View of Planning Element
Do you have any ideas to explain this case, a solution so that this constraint is respected whatever the other constraints that apply
Thanks for your help
18 Sep 2020 14:18 - 18 Sep 2020 14:19 #2 by alainforma
Have you replanned the project ?
if not, do it. Same behaviour ?
Last edit: 18 Sep 2020 14:19 by alainforma.
18 Sep 2020 14:43 #3 by QUANTAMEDICAL
Of course, at least 20 time since problem was discovered
Planning is recalculated each day
Same behaviour
18 Sep 2020 14:46 #4 by alainforma
OK,
Gonna try to reproduce and find the solution !
18 Sep 2020 15:26 #5 by QUANTAMEDICAL
No milestone linked to this task
18 Sep 2020 15:27 #6 by alainforma
Is there some real work entered into the succesor ?
Is the sucessor is planified with a special mode as regular beetween to dates or planified intervention ?
Time to create page: 0.069 seconds
