ProjeQtOr free project management software - HR module - "quantity" went crazy - ProjeQtOr
04 Aug 2020 14:43 #1 by zygglo
For several days, the HR module was behaving correctly. We didn't change parameters, didn't add or remove employees etc. Only new 'leaves periods' were added. However, yesterday (Monday again), 'quantity' values for all employees 'went crazy': previously set actual leave limits were replaced with nonsensical values. Can anyone suggest what mechanism is responsible for making this mess?
20 Aug 2020 11:12 #2 by babynus
Manually entering "Leaves periods" may lead to weird behavior.
You may have unconsistency with existing ones.
You should do this only to add leaves periods for past periods (employee having leaves earned before setup of this feature)
You should not do this for future periods, the system will do it automatically.
20 Aug 2020 13:05 #3 by zygglo
So, it is not recommended to add leaves period the way:
Human resources/Leaves periods/[green +]?
Yes it is probable the reason of our problems - we ALWAYS do it such a way.
NOW I understand that correct operations are:
Leaves calendar-> To record or change your absences, double clicking on an existing date or absence
... as described in HR help.
Many thanks,
Zygmunt
