ProjeQtOr free project management software - No more indicator for planned due date - ProjeQtOr
04 Aug 2020 08:22 #1 by fmt
With ProjeQtOr V8.5.3 (266), previously created actions, with currently passed due date, did'nt trig "respect of planned due date" indicator (and consequently no pop-up alert).
In parallel, if I create a new item with a past due date, the indicator is triggered (as expected) and pop-up alert raises (also as expected).
Is that a regression from Ticket #4794 (see No more Projeqtor notifications ?
Thanks,
fmt
04 Aug 2020 11:10 - 04 Aug 2020 11:13 #2 by Flou
Have you the indicator on the project ? or you just don't have the pop up?
And other users received the alert?
Last edit: 04 Aug 2020 11:13 by Flou.
04 Aug 2020 11:15 #3 by fmt
As explained, I don't get indicator (neither pop-up alert).
04 Aug 2020 11:27 - 04 Aug 2020 11:30 #4 by Flou
Can you try to reproduce this on projeqtor demo please.
That we can have the same case as you, and understand the issue.
Last edit: 04 Aug 2020 11:30 by Flou.
05 Aug 2020 08:03 #5 by fmt
I couldn't exactly reproduce.
Nevertheless, the indicators finally triggered after I updated the untriggered actions... (i.e. I just modified a field value, saved, and missed indicator finally triggered - and pop-up raised).
Could it be related to Actions created under this previous Projeqtor version where there was a pop-up raising issue (see my message above) ?
Can you suggest a way to "update" items (like I did when I just modified a field value) to ensure they will be reconsidered in the indicator triggering process ?
Thanks,
fmt
05 Aug 2020 10:43 #6 by Flou
the problem is possibly with the cron, if it is not running.
Check it, and if it's running restart it.
