ProjeQtOr free project management software - Project expenses : 0 cost is considered NULL - ProjeQtOr
04 Jun 2020 15:34 #1 by fsouliers
today, something fantastic happened : we forecasted an expense (with planned value etc ...) for some components and we should have paid for it ... but the manufacturer gave it to us, as demonstration/testing samples (wooohooo \o/ )
So I wanted to fill the real expense cost : 0€ ... but Projeqtor sees it as a null value.
This is annoying because it’s not null, it is precisely 0. The expense isn’t cancelled and has been properly filled (null necessarily stands for « this data still has no value »).
I savagely modified the database (setting a 0 value and the realDate) : the gui properly updates, but when I click «save», it brings back the null value (and updates the DB with null).
04 Jun 2020 18:13 #2 by babynus
Yes,
It is due to PHP 7.2 compatibility, since in PHP 7.2 :
Before PHP 7.2
1 + null = 1
Since PHP 7.2
1 + null => RAISE ERROR
So all our consolidations failed and we had to replace all null numeric values with zero.
That why now null and zero is the same for numeric values.
I'm afraid we won't be able to change this.
I suggest you just don't enter a real date : there was no bill, so no bill date, so no expense real date.
And possibly move the expense to a specific stauts, closed but not cancelled.
12 Jun 2020 15:58 #3 by fsouliers
many thanks for your answer.
For my better understanding, can you tell me how to start looking for it in the code ?
to be perfectly honest, I would like to understand why a null coalescing operator could not solve the issue, is it to maintain same code with several versions of PHP ? another reason ?
... I am not a PHP developper, so I am just trying to understand.
18 Jun 2020 16:22 - 18 Jun 2020 16:23 #4 by babynus
everywhere...
ad every operation with object fields (additions, substractions,multiplications or others)
Of course a coalescing operator could solve the issue,
but whould require to change al the code, with major regression risks.
So solution was applied at the persistence framework to replace null witj zero for numeric, without any other impact and no risk of regression.
Last edit: 18 Jun 2020 16:23 by babynus.
