ProjeQtOr free project management software - [SOLVED] Installation V8.4.4.1 - No datsbase - ProjeQtOr
22 May 2020 10:19 #1 by moserwi
OK I tracked it down:
First installation screen, all green
Then it creates the database but the tables.sql are not executed.
A test to pupulate the database out of projeqtor/db fails due to non existent "if !exists create table" statements
In fact i have no idea how this can work as I did not find any create_tables.sql or such.
Tks - wili
25 May 2020 11:59 #2 by babynus
After configuration, you must connect to the application with account admin/admin.
This will populate the DB.
26 May 2020 14:01 #3 by moserwi
OK not possible to add attachments - reply by mail
26 May 2020 14:08 #4 by moserwi
Tried with MySQL:
see results:
26 May 2020 17:51 #5 by babynus
You must give write access to PHP user on some folders :
- at least on projector/files and all subfolders.
NB : better grant all access to projeqtor structure during installation.
26 May 2020 20:31 #6 by moserwi
root@pm:/home# chmod -R 777 projeqtor
(includes files structure)
login admin/admin
ERROR : An error occurred on 2020-05-26 at 20:26:27
phpmyadmin: no tables found
