ProjeQtOr free project management software - No access to HR module with admin log - Page 3 - ProjeQtOr
28 Sep 2020 08:10 - 28 Sep 2020 08:29 #13 by ashofphoenix
Hi Babynus.
Already posted on previous history...
BRAINSTORMING !!!!!
Got a ligthning in my mind. I thought it was "admin" as leave system administrator but it was a clone test... :( so stupid....
But still got a Problem :"admin" is not listed in possible "Leave System Administrator" and only users declared as a resource are listed.
How to make "admin" appear in this list without being a ressource ?
Last edit: 28 Sep 2020 08:29 by ashofphoenix.
28 Sep 2020 14:21 #14 by babynus
This is a restriction.
So just try a workaround :
check "isResource" on admin.
Set him as administrator of leave system.
Uncheck "isResource" on admin.
28 Sep 2020 15:20 - 28 Sep 2020 15:27 #15 by ashofphoenix
99.99% solved, just can't access Leave Calendar and Leave Dashboard :P (Even with Administrator of the leave system rights ON to access that calendar/dashboard) As you can see reason is obvious ^^ )
BTW, what is the slight difference between VIEW access and READ access in that case ? View is for form and Read is for data ?
Last edit: 28 Sep 2020 15:27 by ashofphoenix.
28 Sep 2020 15:35 #16 by babynus
This is absolutely normal.
As an admin, you can manage leave system parameters, but if admin is not an employee, he doesn't have access to leaves features
28 Sep 2020 15:38 - 28 Sep 2020 15:42 #17 by ashofphoenix
Side Effect, If I uncheck "isressource" to admin just after put in as admin of leave system, I still got access to HR menu/configuration with admin login, but leave system administrator goes back to my personal account (employee/ressource) and doesn't stay to admin account
Last edit: 28 Sep 2020 15:42 by ashofphoenix.
