ProjeQtOr free project management software - exported MS Project XML zero size - ProjeQtOr
30 Apr 2020 10:13 #1 by jocward
We are on V7.4.4 and when exporting gantt chart from planning the resulting MS Project XML file has zero content (0kB)
Any ideas?
Kind Regards
J
30 Apr 2020 10:28 #2 by babynus
Do you have any error on log file ?
NB : possibly this is an issue that is fixed on more recent versions.
If you have the opportunity to test on last stable release, please do.
