ProjeQtOr free project management software - [SOLVED] Not allowing me to upload file size larger than 2MB - ProjeQtOr
29 Apr 2020 08:02 #1 by iconic
I change the global parameters for the max allowed size to 10M as the help manual shows but I receive an error telling me that cannot upload more than 2MB due to upload_max_filesize
I check my php.ini file and it shows 128 MB.
Is this a know fault?
29 Apr 2020 08:05 #2 by iconic
No need to reply. Please ignore. When I changed the php version with the latest update I did not update the php version to the right size.
