ProjeQtOr free project management software - [SOLVED] # link not updated V8.4.3 - Page 2 - ProjeQtOr
01 Jul 2020 09:18 #7 by babynus
Replied by babynus on topic # link not updated V8.4.3
Really cannot reproduce :
Maybe it is linked to specific use case...
Could you please try and reproduce on demo.projeqtor.org, so that we have a use case to test (and then fix) ?
01 Jul 2020 09:45 - 01 Jul 2020 10:01 #8 by ashofphoenix
done...
Last edit: 01 Jul 2020 10:01 by ashofphoenix.
01 Jul 2020 10:00 #9 by babynus
Thanks for thje reference.
I think there is another issue on that document : the count is correct, in fact same ticket is references twice...
I'll have a look.
But I'm not sure it is same use case as yours.
01 Jul 2020 10:02 #10 by ashofphoenix
please check again the update of my previous post from demo site
01 Jul 2020 10:04 #11 by babynus
I examined use case on demo, and this gave me some hints.
It seems that all items linked to Document and to Documents Versions are listed, but only items linked to Document itself are counted...
Is it your case ? ( Products are linked to Document, Product Versions are linked to Document Versions of this document)
01 Jul 2020 11:19 #12 by ashofphoenix
That's quite obvious.
I do link Version of product to a specific version of document (a version of production is refered to its updated definition document for exemple)
So as you said, only "direct link" seems to be counted.
BTW, I also check some other documents, and It also seems that test sessions linked to a specific version of document don't seem to be counted aswell on the document "linked elements"
