ProjeQtOr free project management software - [SOLVED] Problem with the template plugin (v8.4.1) - ProjeQtOr
27 Mar 2020 12:08 #1 by Thierry94
Hi
I use the template plugin for a while without any problem, especially for meeting minutes and invoices.
The end of the month is coming, I want to generate my invoices but I can't. No report generation possible with my template from the invoice screen (while it worked last month).
Looking at the template plugin settings screen, I see that the invoice template (element type: invoice) seems to be assigned to the 'sales order' type (the template test asks me for a sales order number...).
Similarly, my meeting minutes template is now assigned to 'vendor payment'.
I am of course on version 8,4,1.
I reinstalled the template plugin, but the result is the same.
I think there is a discrepancy between the element selected in the report template settings and the element to which it is actually assigned.
Thanks for your help.
29 Mar 2020 23:59 #2 by babynus
Issue is already identified.
Fix will be deployed on V8.4.2
You can find patch attached
30 Mar 2020 06:59 #3 by Thierry94
Thank you very much.
the patch has the effect of replacing projeqtor/view/print.php.
I modified the rights of this file (httpd:root), restarted the web server.
But the problem is still the same. Nothing changes in the settings window of the template plugin. The invoice template for example still seems to be assigned to customer orders ...
30 Mar 2020 09:38 #4 by babynus
This is another issue, already fixed.
Patch attached
The following user(s) said Thank You: Thierry94
30 Mar 2020 10:28 #5 by Thierry94
it works. Thanks a lot :)
