ProjeQtOr free project management software - [SOLVED] Fatal Error in Installation: Cannot redeclare mb_str_split() - ProjeQtOr
29 Feb 2020 16:27 #1 by sinbad1965
I keep getting the following error message when I try to open the application:
Fatal error: Cannot redeclare mb_str_split() in /opt/lampp/htdocs/projeqtor/tool/projeqtor.php on line 2253
NB I am new to programing and coding etc..
01 Mar 2020 13:58 #2 by babynus
You try and install PrijeQtOr V8.3 on PHP V7.4
ProjeQtOr V8.3 requires PHP from V5.6 to V7.3 and is not compatible with PHP V7.4
Compatibility will be brought by ProjeQtOr V8.4
02 Mar 2020 10:05 #3 by sinbad1965
Thank you for the reply.
When will 8.4 be ready
