ProjeQtOr free project management software - Screen customization plug-in: Mandatory fields should be displayed empty - ProjeQtOr
07 Feb 2020 10:04 #1 by fmartin
When I create a ticket, and the object has been modified with mandatory fields:
- Priority
- Responsible
- Ticket Type
The first ID of each list is the one that is displayed by default. It shouldn't be like this.
The drop down list should be empty/mandatory and user should click on the list to select the correct value.
07 Feb 2020 10:15 #2 by alainforma
HI,
Yes, The list keeps the first object on the list type or value sorted by order.
Then it is bothering you , you can add an object with a "symbol" or a text like " please select " to be the first in order sort. It is a solution.
07 Feb 2020 10:21 #3 by fmartin
This is a workaround that is actually not fully functional.
The field is mandatory so I expect user to select the proper value. If I create a value like you said " Select Responsible" to have it on the top of the list by default, a user could save the ticket anyway with this "user", therefore, this is wrong to me.
07 Feb 2020 10:38 #4 by alainforma
yes this workaround has its limits.
07 Feb 2020 10:50 #5 by fmartin
07 Feb 2020 10:53 #6 by alainforma
No. It is fixed this way. On a mandatory field, the first object of the list is selected by default.
