ProjeQtOr free project management software - [SOLVED] Kanban - ProjeQtOr
[SOLVED] Kanban
30 Jan 2020 14:56 #1 by NorbertD
Kanban was created by NorbertD
hello together
i have upgraded to 8.3.2 from 8.2.x (in which the plugin Kanban and liveMeeting were included).
Now kanban is not longer in the menu. It works when i start a live meeting.
in the old version it was startable from the menue
if have restarted with new cache (the icon for Change Requests menue icon is now visible)
thank you for your help
Norbert
31 Jan 2020 12:20 - 31 Jan 2020 12:22 #2 by Flou
Replied by Flou on topic Kanban
Indeed there is an error with kanban when we go from a version 8.2.x.
We will patch this error in the next version.
While waiting for the patch, just delete the lines in the plugin table that have the name kanban.
Last edit: 31 Jan 2020 12:22 by Flou.
The following user(s) said Thank You: NorbertD
