ProjeQtOr free project management software - Running of Cron is not correctly checked - ProjeQtOr
04 Jan 2020 08:28 #1 by burgerzs
It seems to me that when the running of Cron is checked in Cron relaunch(), then it is not taken into account that in RUNNING file there are more items, not only the time. e.g. 1578120959|879|5e1036d65c5751.75848963
Thus Cron is relaunched after a user logs in.
As a temporary correction I changed:
$last=fgets($handle);
to this:
$tmp_runningfile=fgets($handle);
$tmp_runningfile_array=explode("|",$tmp_runningfile);
$last=reset($tmp_runningfile_array);
It seems to be ok now.
Zsolt
06 Jan 2020 17:40 #2 by babynus
You are right.
The changes done on Cron::check() where not done on Cron::relaunch().
Thanks for pointing out the issue and proposing a patch.
Fix will be included in V8.3.2
