ProjeQtOr free project management software - Update module doesn't work ! - ProjeQtOr
17 Dec 2019 14:03 #1 by g.sangla
I'm trying to update my Projeqtor install using the module as previously but it doesn't work.
" RequestError: Unable to load ../plugin/installAuto/installAutoDownload.php?plgInstallAutoVersion=V8.2.4 status: 500 "
It seems that the problem is on the update server side.
Could you please help me ?
18 Dec 2019 11:23 #2 by babynus
I have a look and keep you informed
18 Dec 2019 11:26 #3 by babynus
I cannot reproduce the issue.
Which version of the plugin are you using ?
Do you have any error on log file ?
18 Dec 2019 13:42 #4 by g.sangla
The plugin version for "Install Auto" is v1.4 installed on 15/04/2019 on v7.4.3.
18 Dec 2019 14:04 #5 by babynus
Do you have any error on log projeqtor file ?
