ProjeQtOr free project management software - 'user' was connected through API and should not reach Application for same sessi - ProjeQtOr
26 Nov 2019 13:02 #1 by aleleve
Dear all,
I tried to use the web interface while testing some API requests but since the upgrade to 8.2.4, it raises an exception;
'user' was connected through API and should not reach Application for same session. May be a hacking attempt from IP 127.0.0.1
Is there a way to avoid it please without modifying the source code on each upgrade ?
All the best
Arnaud
04 Dec 2019 11:34 #2 by babynus
No,
It is a security we added to avoid use of API through cross sote scripting hacking.
If you want to test API and have a session opened, you must use different browsers.
The following user(s) said Thank You: aleleve
26 Feb 2020 17:58 #3 by antoine1003
What if we need the API in a JS file that will use the same session? --'
26 Feb 2020 18:09 #4 by babynus
ProjeQtOr API is not designed for such use.
If you use same session, just use existing services (in /tool)
