ProjeQtOr free project management software - 8.1.8 Issue with several reports - ProjeQtOr
18 Oct 2019 10:21 - 18 Oct 2019 10:28 #1 by fsouliers
when displaying the report costs->project expense per month : the result is totally wrong. In my case, I only see one month (December 2019) with a weird planned expense amount (it is definetly not matching the expenses planned in December).
when displaying the report KPI->KPI Deliverable for project, selecting a given project, current year and current month : the first table is OK, but in the second and in the first graph, the weeks are not in a chronological order (they actually seem to be ordered in a strange way) ... making the report unusable.
when displaying the report resources -> resource workforce : it shows an empty capacity whereas several resources are available fulltime.
it seems that the reports resources -> input/output & seniority have got the same kind of problem.
If needed, I can provide an anonymized copy of our database.
Last edit: 18 Oct 2019 10:28 by fsouliers. Reason: missing info
18 Oct 2019 15:26 #2 by babynus
Ticket #4260 recorded for analysis
08 Nov 2019 16:38 #3 by Gautier
I'm analysing your problem.
For the report Project expense per month : To me it works well.
If you have planned and real expense we just treat the real expense.
We are treating the planned expense without real expense.
For the others report, could you post screenshot for analyse your request please.
12 Nov 2019 09:26 #4 by fsouliers
Here are the screenshots of the reports I have.
For the HR report, I understood the problem : the report does not take resources into account if the fields of the misclaneous section aren't filled.
I am also going to upgrade and check again after.
Thanks !
12 Nov 2019 16:04 - 12 Nov 2019 16:13 #5 by babynus
First report seems correct : you only have planned expenses on same date (december of 2020).
Second report : issue on dates will be fixed on V8.2.4
Last edit: 12 Nov 2019 16:13 by babynus.
13 Nov 2019 07:44 #6 by fsouliers
Hi all,
here are the expenses for this project ... I can't understand why they would all be considered as planned in December 2020.
Hope this helps,
