ProjeQtOr free project management software - [SOLVED] 8.1.8 Issue in budget calculation - ProjeQtOr
17 Oct 2019 17:03 #1 by fsouliers
it seems there is a bug in the budget calculation : when a project expense is marked as done, it is no longer taken into account in the budget calculation (its amount is ignored). This should occur only with canceled expenses.
As far as I remember, the behavior was correct in 8.0.6
17 Oct 2019 17:39 #2 by babynus
Issue recorded as Ticket #4256
17 Oct 2019 17:57 #3 by babynus
Issue fixed fix is to replace line 441 in model/BudgetMain.php from
$expList=($this->id)?$exp->getSqlElementsFromCriteria(array('idBudgetItem'=>$this->id,'idle'=>'0')):array();
to
$expList=($this->id)?$exp->getSqlElementsFromCriteria(array('idBudgetItem'=>$this->id,'cancelled'=>'0')):array();
The following user(s) said Thank You: fsouliers
18 Oct 2019 10:30 #4 by fsouliers
ok, it works, many thanks !
