ProjeQtOr free project management software - [SOLVED] Notes disappear when a checklist is affected to a project - ProjeQtOr
15 Oct 2019 17:58 #1 by LEADER
Notes and attached files disappear when I link a checklist to a project. Is it normal ? or, a specific configuration somewhere ?
Thank you in advance for your return
16 Oct 2019 10:49 #2 by babynus
Which version are you using ?
16 Oct 2019 11:54 #3 by LEADER
I use the version: 8.2.2
17 Oct 2019 10:19 #4 by babynus
I cannot reproduce.
Can you please show print screen ?
01 Feb 2020 18:09 #5 by LEADER
After update version. Problem solved.
