ProjeQtOr free project management software - Field not displayed in ticket screen - ProjeQtOr
01 Oct 2019 19:13 #1 by lsigroup
I select in ticket screen to display fields called "Estimated time" & "Real time" by checking checkbox, but once i click on OK button, they do not appear. Please help.
02 Oct 2019 08:39 #2 by tblanken
Can you send a screenshot?
Normally in tickets you have a field to enter estimated time - here you enter e.g. "2" days.
After you saved your ticket, you can use the button "dispatch" to get a popup where you can enter worktimes per day. These values are sumed up in field "real".
Best regards,
Torben
02 Oct 2019 18:38 #3 by lsigroup
Please find it attached. Those fields cannot be displayed in ticket above table.
04 Oct 2019 08:27 #4 by tblanken
Which version are you using. E.g. in version 8.2.0 it is possible since I use it myself. Maybe updating your version can solve your problem.
Best regards
