ProjeQtOr free project management software - Custom screen - ProjeQtOr
Custom screen
10 Sep 2019 19:06 #1 by Durou C
Custom screen was created by Durou C
I just move to 8.1.6 version,
I need to do some custom field on opportunities,
and now I got error:
2019-09-10 19:02:07.160 ***** ERROR ***** [V8.1.6] on file '/var/www/projeqtor/model/persistence/SqlElement.php' at line (2989)
2019-09-10 19:02:07.160 ***** ERROR ***** [V8.1.6] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-10 19:02:59.504 ***** ERROR ***** [V8.1.6] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor_test.opportunitymain' doesn't exist
2019-09-10 19:02:59.504 ***** ERROR ***** [V8.1.6] For query : select * from opportunitymain where id=83
2019-09-10 19:02:59.504 ***** ERROR ***** [V8.1.6] Strack trace :
2019-09-10 19:02:59.504 ***** ERROR ***** [V8.1.6] #0 Sql->query called at [/var/www/projeqtor/model/persistence/SqlElement.php:2931]
2019-09-10 19:02:59.504 ***** ERROR ***** [V8.1.6] #1 SqlElement->getSqlElement called at [/var/www/projeqtor/model/persistence/SqlElement.php:669]
2019-09-10 19:02:59.504 ***** ERROR ***** [V8.1.6] #2 SqlElement->__construct called at [/var/www/projeqtor/model/OpportunityMain.php:125]
2019-09-10 19:02:59.504 ***** ERROR ***** [V8.1.6] #3 OpportunityMAin->__construct called at [/var/www/projeqtor/model/custom/Opportunity.php:192]
2019-09-10 19:02:59.504 ***** ERROR ***** [V8.1.6] #4 Opportunity->setAttributes called at [/var/www/projeqtor/view/objectDetail.php:640]
2019-09-10 19:02:59.504 ***** ERROR ***** [V8.1.6] #5 drawTableFromObject called at [/var/www/projeqtor/view/objectDetail.php:311]
2019-09-10 19:02:59.504 ***** ERROR ***** [V8.1.6] ERROR *****
2019-09-10 19:02:59.504 ***** ERROR ***** [V8.1.6] on file '/var/www/projeqtor/model/persistence/SqlElement.php' at line (2989)
2019-09-10 19:02:59.504 ***** ERROR ***** [V8.1.6] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-10 19:02:59.504 ***** ERROR ***** [V8.1.6] on file '/var/www/projeqtor/model/persistence/SqlElement.php' at line (2991)
2019-09-10 19:02:59.504 ***** ERROR ***** [V8.1.6] Error on SqlElement to get 'id' for Class 'OpportunityMAin' : field 'id' not found in Database.
2019-09-10 19:02:59.505 ***** ERROR ***** [V8.1.6] ERROR *****
2019-09-10 19:02:59.505 ***** ERROR ***** [V8.1.6] on file '/var/www/projeqtor/model/persistence/SqlElement.php' at line (2989)
2019-09-10 19:02:59.505 ***** ERROR ***** [V8.1.6] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-10 19:02:59.505 ***** ERROR ***** [V8.1.6] on file '/var/www/projeqtor/model/persistence/SqlElement.php' at line (2991)
2019-09-10 19:02:59.505 ***** ERROR ***** [V8.1.6] Error on SqlElement to get 'reference' for Class 'OpportunityMAin' : field 'reference' not found in Database.
2019-09-10 19:02:59.505 ***** ERROR ***** [V8.1.6] Error on SqlElement to get 'name' for Class 'OpportunityMAin' : field 'name' not found in Database.
2019-09-10 19:02:59.505 ***** ERROR ***** [V8.1.6] Error on SqlElement to get 'idOpportunityType' for Class 'OpportunityMAin' : field 'idOpportunityType' not found in Database.
2019-09-10 19:02:59.506 ***** ERROR ***** [V8.1.6] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-10 19:02:59.506 ***** ERROR ***** [V8.1.6] ERROR *****
2019-09-10 19:02:59.506 ***** ERROR ***** [V8.1.6] on file '/var/www/projeqtor/model/persistence/SqlElement.php' at line (2991)
2019-09-10 19:02:59.506 ***** ERROR ***** [V8.1.6] Error on SqlElement to get 'idProject' for Class 'OpportunityMAin' : field 'idProject' not found in Database.
2019-09-10 19:02:59.506 ***** ERROR ***** [V8.1.6] on file '/var/www/projeqtor/model/persistence/SqlElement.php' at line (2989)
2019-09-10 19:02:59.506 ***** ERROR ***** [V8.1.6] Error on SqlElement to get 'creationDate' for Class 'OpportunityMAin' : field 'creationDate' not found in Database.
2019-09-10 19:02:59.506 ***** ERROR ***** [V8.1.6] Error on SqlElement to get 'idUser' for Class 'OpportunityMAin' : field 'idUser' not found in Database.
2019-09-10 19:02:59.507 ***** ERROR ***** [V8.1.6] Error on SqlElement to get 'idSeverity' for Class 'OpportunityMAin' : field 'idSeverity' not found in Database.
2019-09-10 19:02:59.507 ***** ERROR ***** [V8.1.6] ERROR *****
2019-09-10 19:02:59.507 ***** ERROR ***** [V8.1.6] on file '/var/www/projeqtor/model/persistence/SqlElement.php' at line (2989)
2019-09-10 19:02:59.507 ***** ERROR ***** [V8.1.6] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-10 19:02:59.507 ***** ERROR ***** [V8.1.6] on file '/var/www/projeqtor/model/persistence/SqlElement.php' at line (2991)
2019-09-10 19:02:59.507 ***** ERROR ***** [V8.1.6] Error on SqlElement to get 'idLikelihood' for Class 'OpportunityMAin' : field 'idLikelihood' not found in Database.
2019-09-10 19:02:59.507 ***** ERROR ***** [V8.1.6] Error on SqlElement to get 'idCriticality' for Class 'OpportunityMAin' : field 'idCriticality' not found in Database.
2019-09-10 19:02:59.507 ***** ERROR ***** [V8.1.6] Error on SqlElement to get 'impactCost' for Class 'OpportunityMAin' : field 'impactCost' not found in Database.
2019-09-10 19:02:59.508 ***** ERROR ***** [V8.1.6] ERROR *****
2019-09-10 19:02:59.508 ***** ERROR ***** [V8.1.6] on file '/var/www/projeqtor/model/persistence/SqlElement.php' at line (2991)
2019-09-10 19:02:59.508 ***** ERROR ***** [V8.1.6] cause = array_key_exists() expects parameter 2 to be array, boolean given
2019-09-10 19:02:59.508 ***** ERROR ***** [V8.1.6] Error on SqlElement to get 'projectReserveAmount' for Class 'OpportunityMAin' : field 'projectReserveAmount' not found in Database.
2019-09-10 19:02:59.508 ***** ERROR ***** [V8.1.6] on file '/var/www/projeqtor/model/persistence/SqlElement.php' at line (2989)
11 Sep 2019 09:10 #2 by Durou C
Replied by Durou C on topic Custom screen
the table name of opportunities is change... look:
2019-09-11 08:58:16.810 ***** ERROR ***** [V8.1.6] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor_test.opportunitymain' doesn't exist
11 Sep 2019 09:19 #3 by babynus
Replied by babynus on topic Custom screen
No, we did not change anythiong on opportunities.
I tried and add custom filed withoput issue.
Try and remove customization on opportuinity.
Then do it again.
It issue persists, please post here file /model/custom/Opportunity.php
11 Sep 2019 09:33 #4 by Durou C
<?php
/*** COPYRIGHT NOTICE *********************************************************
* Copyright 2009-2017 ProjeQtOr - Pascal BERNARD - This email address is being protected from spambots. You need JavaScript enabled to view it.
* Contributors : -
* This file is part of ProjeQtOr.
* ProjeQtOr is free software: you can redistribute it and/or modify it under
* the terms of the GNU Affero General Public License as published by the Free
* Software Foundation, either version 3 of the License, or (at your option)
* any later version.
* ProjeQtOr is distributed in the hope that it will be useful, but WITHOUT ANY
* WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
* FOR A PARTICULAR PURPOSE. See the GNU Affero General Public License for
* more details.
* You should have received a copy of the GNU Affero General Public License along with
* ProjeQtOr. If not, see <www.gnu.org/licenses/>.
* You can get complete code of ProjeQtOr, other resource, help and information
* about contributors at www.projeqtor.org
*** DO NOT REMOVE THIS NOTICE ************************************************/
* Opportunity.
require_once('_securityCheck.php');
class Opportunity extends OpportunityMain {
public $_sec_description;
public $id;
public $reference;
public $produit;
public $name;
public $idOpportunityType;
public $idProject;
public $creationDate;
public $idUser;
public $idSeverity;
public $idLikelihood;
public $idCriticality;
public $impactCost;
public $projectReserveAmount;
public $Origin;
public $cause;
public $impact;
public $description;
public $_sec_treatment;
public $idStatus;
public $idResource;
public $idPriority;
public $initialEndDate;
public $actualEndDate;
public $handled;
public $handledDate;
public $done;
public $doneDate;
public $idle;
public $idleDate;
public $cancelled;
public $_lib_cancelled;
public $result;
public $_sec_Link;
public $_nbColMax=3;
public static $_customFields=array(
'produit'
private static $_fieldsAttributes=array(
"id"=>"nobr",
"reference"=>"readonly",
"name"=>"required",
"idProject"=>"required",
"idStatus"=>"required",
"idOpportunityType"=>"required",
"creationDate"=>"required",
"handled"=>"nobr",
"done"=>"nobr",
"idle"=>"nobr",
"idleDate"=>"nobr",
"cancelled"=>"nobr",
"projectReserveAmount"=>"readonly",
"produit"=>""
private static $_staticDisplayStyling=array(
private static $_colCaptionTransposition=array(
"produit"=>"plgProduit"
public static $_defaultValues=array(
* Constructor
* @param $id the id of the object in the database (null if not stored yet)
* @return void
function __construct($id = NULL, $withoutDependentObjects=false) {
parent::__construct($id,$withoutDependentObjects);
* Destructor
* @return void
function __destruct() {
parent::__destruct();
* Return the specific fieldsAttributes
* @return the fieldsAttributes
protected function getStaticFieldsAttributes() {
return array_merge(parent::getStaticFieldsAttributes(),self::$_fieldsAttributes);
* Return the specific styling for fields
* @return the fields styling
public function getStaticDisplayStyling() {
return self::$_staticDisplayStyling;
* Set attribut from parent : merge current attributes with those of Main class
* @return void
public function setAttributes() {
$parentClass=get_class($this)."Main";
if (!SqlElement::class_exists($parentClass)) return;
$parent=new $parentClass($this->id);
if (! method_exists($parent, "setAttributes")) return;
$parent->setAttributes();
if (method_exists("SqlElement","mergeAttributesArrays")) {
self::$_fieldsAttributes=SqlElement::mergeAttributesArrays(self::$_fieldsAttributes,$parent->getStaticFieldsAttributes());
} else {
self::$_fieldsAttributes=array_merge_preserve_keys(self::$_fieldsAttributes,$parent->getStaticFieldsAttributes());
* Return the specific colCaptionTransposition
* @return the colCaptionTransposition
protected function getStaticColCaptionTransposition($fld=null) {
if (isset(self::$_colCaptionTransposition)) {
return array_merge(parent::getStaticColCaptionTransposition($fld),self::$_colCaptionTransposition);
} else {
return parent::getStaticColCaptionTransposition($fld);
* Return the generic defaultValues
* @return the layout
protected function getStaticDefaultValues() {
return self::$_defaultValues;
11 Sep 2019 10:01 #5 by babynus
Please attaxch file (copy is hard to compare with expected)
11 Sep 2019 10:03 #6 by Durou C
I cannot send *.php files on this forum
Time to create page: 0.083 seconds
