ProjeQtOr free project management software - Read only field unlocked - ProjeQtOr
27 Aug 2019 23:54 #1 by lsigroup
Always in the same spirit that fields appearing or not depending on custom plugin setup, when i switch from a status to another one, knowing that for those 2 status the field "Charge" is supposed to be in read only mode, how can you explain that this field become updatable when i select the new status in DDL, but after saving become read only again ? It is risky as the user is able to update the field between the 2 status change...
I hope to be clear enough.
03 Sep 2019 18:13 #2 by babynus
Replied by babynus on topic Read only field unlocked
You(re right, issue is confirmed : field is no locked when selecting status
Issue recorded as Ticket #4182
NB : behavior is correct for "required" attribute.
