ProjeQtOr free project management software - Custom Fields appearing too soon - ProjeQtOr
23 Aug 2019 20:16 #1 by lsigroup
I manage in customization screen plugin a field that is supposed to appear by changing statuts in REPONDU (ticket screen as attachment). it works but too soon creating confusion.
Indeed, it appears blanck and without any label when i click on Status DDL but not committing transaction yet.
Why this new screen does not appear only when clicking on SAVE button ?
23 Aug 2019 21:30 #2 by babynus
It is same behavior for hide/visible, readonly and required fields : fields attribributes are dynamically set "as soon as possible".
For instance, for mandatory fields, it is important to see field is required before saving.
Also for fields appearing from a status, it means user should be able to entef data before saving.
27 Aug 2019 08:29 #3 by lsigroup
Ok, understood, but why only the field appears but not its label. It creates confusion.
27 Aug 2019 08:49 #4 by lsigroup
And also not at the final location (field appearing on the left)
29 Aug 2019 16:10 #5 by babynus
I don,t' understand last 2 remarks
Please explain.
30 Aug 2019 10:24 #6 by lsigroup
When we are "between" the 2 status, the field is appearing (blank field) but not its name
