ProjeQtOr free project management software - Strange problem with a new installation 8.1.2 - ProjeQtOr
23 Jul 2019 17:11 #1 by surfufu
using mysql
I had been able to create 2 users, I closed the guest, for all the next users created, it was impossible to login / change the password
log :
2019-07-23 16:39:54.716 ***** ERROR ***** [V8.1.2] on file '/var/www/html/Prj3dRTeam/model/UserMain.php' at line (436)
2019-07-23 16:39:54.716 ***** ERROR ***** [V8.1.2] cause = Undefined index:
2019-07-23 16:40:33.230 ***** ERROR ***** [V8.1.2] ERROR *****
2019-07-23 16:40:33.230 ***** ERROR ***** [V8.1.2] on file '/var/www/html/Prj3dRTeam/model/UserMain.php' at line (436)
2019-07-23 16:40:33.230 ***** ERROR ***** [V8.1.2] cause = Undefined index:
2019-07-23 16:40:58.731 ***** ERROR ***** [V8.1.2] ERROR *****
fix :
I realized that the problem was link to the id 123 of the table accessright with the value #10 to idAcessProfile
the last id of the table accessprofile was #9 and not #10 ... after a little research in the *.sql file i found :
-- V8.1 : remove this accessprofile which is no used
--INSERT INTO `${prefix}accessprofile` (`id`,`name`,`description`,`idAccessScopeRead`,`idAccessScopeCreate`,`idAccessScopeUpdate`,`idAccessScopeDelete`,`sortOrder`,`idle`) values
--(10,'accessReadOwnOnly',null,2,1,1,1,900,0);
INSERT INTO `${prefix}accessright` (`idProfile`, `idMenu`, `idAccessProfile`) VALUES
(1, 91, 1),
(2, 91, 1),
(3, 91, 1),
(4, 91, 10),
(6, 91, 10),
(7, 91, 10),
(5, 91, 10);
and this look like my problem ... so i added the id #10 with
(10,'accessReadOwnOnly',null,2,1,1,1,900,0) in accessprofile
and now it's work ...
even if I don't understand where why I need the id #10 as it look like it had been removed if the 8.1
maybe it's because I canceled the guest ?
have a good day :)
25 Jul 2019 16:43 #2 by babynus
It seems you "closed" an accessScope (screen "Access mode") that was still used by "Access to Data".
After closing an "access mode", you sould take care that all "Access to data" are still relevant.
We'll add a fix in next patch to avoid raising an error.
25 Jul 2019 17:08 #3 by surfufu
I closed the guest to avoid the guest access ... look like the problem
