ProjeQtOr free project management software - Projeqtor 8.0.4 menue Contacts field Function - ProjeQtOr
13 Jun 2019 09:40 #1 by juergens
this concerns the menu Contacts.
When I fill out the field 'Function' (for example in the screen shot 'test') then I get an error message "SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'function='df' where id=84' at line 1"
Attached is the log file and the screen shots of the error message.
Best regards
Juergen
15 Jun 2019 09:48 #2 by babynus
This is duplicate post.
Please remove one of them.
