ProjeQtOr free project management software - View base line saved and compare or at least be able to view - ProjeQtOr
05 Jun 2019 17:20 #1 by beverley
HI
I have tried to get the show base line functionality to work. I have saved two base lines, which have a slightly different version of a simple plan.
1. I have tried loading one of the base lines in the drop down show base line, both in the on top and on bottom, The plan view did not change and I could not see the base line.
2. I have tried selecting one base line file in the top view and another different file in the bottom file name. Again the view did not change.
How to I get to see and highlight the changes?
I have documented this with screen shots in the file attached. Please let me know how this functionality should work.
Thanks Bev
06 Jun 2019 18:10 #2 by babynus
What browser are you using ?
Can you try on Demo ?
Do you have any error on log file or on browser console ?
12 Jun 2019 09:09 #3 by beverley
Hi babynus
I have tried the Demo site too, and get the same issue. I can save a version of the plan, this appears as selectable in the show base line. But using view with show base line, nothing happens. I am using edge browser, I have tried this with chrom too, same issue, can not get the saved plan to appear.
Sorry not sure how to get to any error logs.
Thanks Bev
12 Jun 2019 11:39 #4 by babynus
Give give id and name of the project you tested on Demo.
12 Jun 2019 11:44 #5 by babynus
I found it : it is "Bev Test3"
Strange as I replaced you last baseline with new one "TEST BABYNUS ON BEV TEST 3" and this one works like a charm...
Can you show print screen to explain how you stored baseline ?
12 Jun 2019 12:15 #6 by babynus
I think I found the issue.
Creating baseline from Global Planning does not work.
Ticket #4062 recorded
