ProjeQtOr free project management software - Impossible d'installer Projeqtor - ProjeQtOr
04 Jun 2019 13:54 #1 by bsirgo
Bonjour,
J'essaye désespérément d'installer Projeqtor qui a l'air formidable !
Malheureusement, impossible d'y accéder et de me connecter par admin/admin.
Merci pour votre aide,
Benjamin
LOGS :
2019-06-04 13:32:43.061 ===== TRACE =====
2019-06-04 13:32:43.074 ===== TRACE ===== =====================================
2019-06-04 13:32:43.075 ===== TRACE =====
2019-06-04 13:32:43.076 ===== TRACE ===== DataBase actual Version =
2019-06-04 13:32:43.077 ===== TRACE ===== ProjeQtOr actual Version = V8.0.4
2019-06-04 13:32:43.079 ***** ERROR ***** [] ERROR *****
2019-06-04 13:32:43.080 ***** ERROR ***** [] on file '/customers/5/5/7/sirgo.fr/httpd.www/projeqtorV8.0.4/tool/projeqtor.php' at line (3901)
2019-06-04 13:32:43.081 ***** ERROR ***** [] cause = set_time_limit(): Cannot set max execution time limit due to system policy
2019-06-04 13:32:46.130 ***** ERROR ***** [] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'sirgo_fr_bdd.projeqtor_resource' doesn't exist
2019-06-04 13:32:46.132 ***** ERROR ***** [] For query : select * from projeqtor_resource where projeqtor_resource.name='admin' and projeqtor_resource.isUser = '1'
2019-06-04 13:32:46.133 ***** ERROR ***** [] Strack trace :
2019-06-04 13:32:46.134 ***** ERROR ***** [] #0 Sql->query called at [/customers/5/5/7/sirgo.fr/httpd.www/projeqtorV8.0.4/model/persistence/SqlElement.php:2446]
2019-06-04 13:32:46.135 ***** ERROR ***** [] #1 SqlElement->getSqlElementsFromCriteria called at [/customers/5/5/7/sirgo.fr/httpd.www/projeqtorV8.0.4/model/persistence/SqlElement.php:2743]
2019-06-04 13:32:46.135 ***** ERROR ***** [] #2 SqlElement->getSingleSqlElementFromCriteria called at [/customers/5/5/7/sirgo.fr/httpd.www/projeqtorV8.0.4/tool/getHash.php:48]
2019-06-04 13:32:48.309 ***** ERROR ***** [] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'sirgo_fr_bdd.projeqtor_resource' doesn't exist
2019-06-04 13:32:48.309 ***** ERROR ***** [] For query : select * from projeqtor_resource where projeqtor_resource.name='admin' and projeqtor_resource.isUser = '1'
2019-06-04 13:32:48.310 ***** ERROR ***** [] Strack trace :
2019-06-04 13:32:48.313 ***** ERROR ***** [] #0 Sql->query called at [/customers/5/5/7/sirgo.fr/httpd.www/projeqtorV8.0.4/model/persistence/SqlElement.php:2446]
2019-06-04 13:32:48.314 ***** ERROR ***** [] #1 SqlElement->getSqlElementsFromCriteria called at [/customers/5/5/7/sirgo.fr/httpd.www/projeqtorV8.0.4/model/persistence/SqlElement.php:2743]
2019-06-04 13:32:48.315 ***** ERROR ***** [] #2 SqlElement->getSingleSqlElementFromCriteria called at [/customers/5/5/7/sirgo.fr/httpd.www/projeqtorV8.0.4/tool/getHash.php:48]
2019-06-04 13:41:07.786 ***** ERROR ***** [] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'sirgo_fr_bdd.projeqtor_resource' doesn't exist
2019-06-04 13:41:07.787 ***** ERROR ***** [] For query : select * from projeqtor_resource where projeqtor_resource.name='admin' and projeqtor_resource.isUser = '1'
2019-06-04 13:41:07.788 ***** ERROR ***** [] Strack trace :
2019-06-04 13:41:07.789 ***** ERROR ***** [] #0 Sql->query called at [/customers/5/5/7/sirgo.fr/httpd.www/projeqtorV8.0.4/model/persistence/SqlElement.php:2446]
2019-06-04 13:41:07.789 ***** ERROR ***** [] #1 SqlElement->getSqlElementsFromCriteria called at [/customers/5/5/7/sirgo.fr/httpd.www/projeqtorV8.0.4/model/persistence/SqlElement.php:2743]
2019-06-04 13:41:07.790 ***** ERROR ***** [] #2 SqlElement->getSingleSqlElementFromCriteria called at [/customers/5/5/7/sirgo.fr/httpd.www/projeqtorV8.0.4/tool/getHash.php:48]
2019-06-04 13:41:08.037 ===== TRACE =====
2019-06-04 13:41:08.037 ===== TRACE ===== =====================================
2019-06-04 13:41:08.038 ===== TRACE =====
2019-06-04 13:41:08.039 ===== TRACE ===== DataBase actual Version =
2019-06-04 13:41:08.039 ===== TRACE ===== ProjeQtOr actual Version = V8.0.4
2019-06-04 13:41:08.040 ===== TRACE =====
2019-06-04 13:41:08.041 ***** ERROR ***** [] ERROR *****
2019-06-04 13:41:08.041 ***** ERROR ***** [] on file '/customers/5/5/7/sirgo.fr/httpd.www/projeqtorV8.0.4/tool/projeqtor.php' at line (3901)
2019-06-04 13:41:08.042 ***** ERROR ***** [] cause = set_time_limit(): Cannot set max execution time limit due to system policy
2019-06-04 13:43:44.185 ***** ERROR ***** [] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'sirgo_fr_bdd.projeqtor_resource' doesn't exist
2019-06-04 13:43:44.186 ***** ERROR ***** [] For query : select * from projeqtor_resource where projeqtor_resource.name='admin' and projeqtor_resource.isUser = '1'
2019-06-04 13:43:44.187 ***** ERROR ***** [] Strack trace :
2019-06-04 13:43:44.188 ***** ERROR ***** [] #0 Sql->query called at [/customers/5/5/7/sirgo.fr/httpd.www/projeqtorV8.0.4/model/persistence/SqlElement.php:2446]
2019-06-04 13:43:44.188 ***** ERROR ***** [] #1 SqlElement->getSqlElementsFromCriteria called at [/customers/5/5/7/sirgo.fr/httpd.www/projeqtorV8.0.4/model/persistence/SqlElement.php:2743]
2019-06-04 13:43:44.190 ***** ERROR ***** [] #2 SqlElement->getSingleSqlElementFromCriteria called at [/customers/5/5/7/sirgo.fr/httpd.www/projeqtorV8.0.4/tool/getHash.php:48]
2019-06-04 13:48:55.703 ***** ERROR ***** [] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'sirgo_fr_bdd.projeqtor_resource' doesn't exist
2019-06-04 13:48:55.708 ***** ERROR ***** [] For query : select * from projeqtor_resource where projeqtor_resource.name='admin' and projeqtor_resource.isUser = '1'
2019-06-04 13:48:55.708 ***** ERROR ***** [] Strack trace :
2019-06-04 13:48:55.710 ***** ERROR ***** [] #0 Sql->query called at [/customers/5/5/7/sirgo.fr/httpd.www/projeqtorV8.0.4/model/persistence/SqlElement.php:2446]
2019-06-04 13:48:55.713 ***** ERROR ***** [] #1 SqlElement->getSqlElementsFromCriteria called at [/customers/5/5/7/sirgo.fr/httpd.www/projeqtorV8.0.4/model/persistence/SqlElement.php:2743]
2019-06-04 13:48:55.714 ***** ERROR ***** [] #2 SqlElement->getSingleSqlElementFromCriteria called at [/customers/5/5/7/sirgo.fr/httpd.www/projeqtorV8.0.4/tool/getHash.php:48]
2019-06-04 13:48:57.218 ***** ERROR ***** [] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'sirgo_fr_bdd.projeqtor_resource' doesn't exist
2019-06-04 13:48:57.220 ***** ERROR ***** [] For query : select * from projeqtor_resource where projeqtor_resource.name='admin' and projeqtor_resource.isUser = '1'
2019-06-04 13:48:57.220 ***** ERROR ***** [] Strack trace :
2019-06-04 13:48:57.221 ***** ERROR ***** [] #0 Sql->query called at [/customers/5/5/7/sirgo.fr/httpd.www/projeqtorV8.0.4/model/persistence/SqlElement.php:2446]
2019-06-04 13:48:57.222 ***** ERROR ***** [] #1 SqlElement->getSqlElementsFromCriteria called at [/customers/5/5/7/sirgo.fr/httpd.www/projeqtorV8.0.4/model/persistence/SqlElement.php:2743]
2019-06-04 13:48:57.222 ***** ERROR ***** [] #2 SqlElement->getSingleSqlElementFromCriteria called at [/customers/5/5/7/sirgo.fr/httpd.www/projeqtorV8.0.4/tool/getHash.php:48]
05 Jun 2019 15:42 #2 by babynus
Here is your issue :
Please respect forum rules : post in english
